Daveinet
Jan 13, 2014Explorer
Neither one. Technically, you could not have bought the tow bar either, as you could have saved some money, but you can still work with what you have. Go to http://www.readybrake.com/brake-systems.html and set your self up with ReadyBrake. Its an excellent system, very simple dependable, and works very well. Tons of satisfied user of ReadyBrake users on RVnet, and I have no doubt they will chime in. Its simplicity means there is very little to go wrong. It is the only system that is truly closed loop, and actively provides the correct amount of braking, based on need, rather than a predetermined calculation. I'm very pleased with mine, and my toad weight to RV weight ratio is much more demanding than I any other RV set up I've seen.
38,782 PostsLatest Activity: Sep 10, 2026
