wa8yxm
Jan 13, 2014Explorer III
Both of the systems you cite are "Box in the driver's seat" systems, These must be installed (By you) EVERY TIME you tow, the odds of a mistake go up with each install.. The odds also go up with time on an "Oh, I'm only going a short distance, I'll just forget it this one time" and later wishing you'd not forgotten it.
I much prefer an INSTALLED system.. These systems include in no particular order.
M&G (for motor homes with air brakes IF it will fit your towed)
Air Force One
Invisible Brake
US-Gear Decelarator
Ready Brake
Long list of others.
I have other issues with the box in the driver's seat too.. If you use one consider adding a towed-charge system to your consist. This helps to prevent towed battery run down.. Now I know folks who say they have towed 2 or 3 thousand miles without unhooking using one of these systems and no dead battery on towed... I believe them.. I also believe the ones who say they have towed 2 or 3 HUNDRED miles and the towed was dead. And I know why, (older battery). but, hey.. Why risk it.
Hookup with the US-Gear Decelerator is like 2 seconds. Same for the M&G and Ready Brake, not sure on Air Force one but guessing it's the same, Invisible brake is zero seconds.. YES, zero.. Believe it or not. (It is not called Invisible for nothing) all you do is plug in your tow lights.
Think about this.
Air Force One
Invisible Brake
US-Gear Decelarator
Ready Brake
Think about this.
38,782 PostsLatest Activity: Sep 10, 2026
