path1 wrote:
Bryan said...If you want to improve your brakes, the best thing you can do is upgrade your front axle to one for the '08+ E-series. Bigger rotor, caliper, and pads. Its one of the best upgrades I've done to my van. You can pick up a take-off front axle from QuadVan in Portland for $400. As a bonus, you also get new/better ball joints and suspension bushings, plus an improved radius arm and sway bar design.
Will this bolt up to 2003 F-350? (not E-350)
Thanks
Hmmm. I'm not sure about the F-series 2wd. Sorry.
