pappaone
Jun 05, 2014Explorer
Brake Fluid
I noticed the brake fluid was a little low on MH and was going to add some when I notice what I have says DOT3 HIGH Temperature SYNTHETIC. Not knowing what the present fluid is will it make any dif...
rgatijnet1 wrote:Tim Nowicki wrote:
OP asked about synthetic brake fluid being added to his unknown type. NOBODY answered his question. I was under the impression synthetic brake fluid and regular brake fluid can't be mixed. True or not true? thanks
The answer was given a couple of times....flush the system if you do not know what is in it. Guessing on what will mix or not is impossible if you do not know one of the fluid types. Some fluids will mix and some will not. It is too big of a gamble to add any type of fluid if you don't know what is in there now.
