Starrs's avatar
Starrs
brake fluid?
where is the master cyl at? I need to put brake fluid in and I dont know where? 1989 fleetwood southwind----sorry ---chevy
  • You stated that your MH is a 1989 Southwind, but what chassis is under the MH? Chevy or Ford?
  • the OP clearly says 1989 fleetwood southwind??
    I will assume it has a hydroboost system and MC should be up front on the firewall.That would be my guesstimet
  • If we had crystal balls we could tell what kind of MH chassis, year, and motor home that you have.
    Welcome to the forumm and just add all that info to your signature and then we will know how to help.
  • What MH do you have? helps us help you. Could be that you have a diesel pusher with air brakes for all we know.
