MustangGT
Sep 05, 2016Explorer
Brake Interlock Switch
Hi Guys, I've been away for a while...and the RV has been sitting......
My 1996 V8 Fleetwood Southwind Storm keeps popping fuse #9 in the dash fuse block. That fuse is keeping the RV from starting.
I had replaced the brake interlock switch at the pedal and found a DIY jumper (about a foot long) from one of those wires had broken loose at its far end. I can not find the other end. I have no idea why that switch would have been jumpered, but suspect the other end is shorting. Does anyone know what might be going-on with this fuse/jumper? BTW, the other functions on that circuit, the turn signals and flashers, are also not working of course. I disassembled the multiswitch for the blinkers and cleaned it, but no improvement.
thank you!
thank you!
