RLS7201
Apr 10, 2018Explorer II
So much mis-information. There are 5 brake hoses on your chassis, not 3. It was the chevy P32 chassis that had the brake hose problem, not the Ford F53 chassis. The brake hoses are still in good shape on my 95 F53.
I suspect you'll find the dust boots on the rear calipers have been over heated and are cracked. The OEM phenolic caliper pistons can swell and drag in their bores. You can buy metal pistons and caliper rebuild kits or exchange your calipers for complete units.
Before you attach the new outer pads to the calipers, check fit them in the axle bracket. They needs to float freely in the axle brackets. Most outer pads are a touch too long and need to ground down a little.
As already noted, clean or replace the slide pins and the surfaces they press in to. Use the synthetic grease labeled for brakes on the pins and mounting surfaces. The front slide pins, are much easier to remove if you un-screw the steering stops first. Cleaning and greasing the slide pins is an every other year maintenance item, according to Ford. Also change the brake fluid on a two year schedule.
Unless the rotors are warped or have been scored by metal from the pads, leave them alone. No need to turn them.
Don't go cheap on the pads. $39.95 per axle is not enough to get quality pads. More like $100.00 per axle. :(:(
Not sure why others experience poor braking problems. On one panic stop, my wife got seat belt bruises. Bad brakes won't do that.
Richard
Richard
