Gasman 2 wrote:
smlranger,
Did you get your high mount brake light issue resolved? I think JimM68 is pointing you in the right direction.
To add to what fireup said...
If you only have a single bulb filament that acts as both turn and brake lights, then a diode block is needed so the cyclops only turns on with the brakelights and never with either turn signal. Problem could be there.
Gasman 2
Gasman 2
Still haven't got it working. I have a call into Country Coach tech support. I have completely isolated the LED light and plan to install a relay for it and use the brake light signal to trigger the relay.
