DrewE
Feb 17, 2016Explorer III
wbwood wrote:
We have an e450 where one of the brake lights do not work when brakes are pressed. Tail light works fine. Changed bulb to no avail... any input on that?
You've already done half the troubleshooting, I think.
Working tail light implies that the ground is (probably) good. Working brake light on the other side means that the wiring from the front of the RV to the back is good. The problem logically has to be either the socket or the wiring between the two brake lights. (I'd also check that the new bulb is OK, just for kicks, before diving in too much deeper. It's rare, but far from impossible, for brand new light bulbs to be bad.)
38,774 PostsLatest Activity: Apr 26, 2026
