jimchooz
Aug 09, 2014Explorer
enblethen wrote:
Not by my drawings. The switch prevents feeding front turn signals with brake lights.
If there is a converter in the rear, yes.
ProblemS fixed.
Tracing wires back from lights looking for broken wires, I lost tail lights. Starting with first splice I found, after unwrapping came upon feed for taillights loose in bundle. Re-wrapped and taillights good. Checked brake wire splice and it was good. Moved 2 feet to next splice and wiggling the wires, brake lights came on. Unwrapped and same as othe splice, loose feed. Pulled all splices at the back end and redid. All lights work now.
Thanks for the help along the way, helped rule things out!
Jim
38,774 PostsLatest Activity: Mar 01, 2019
