Front Only? Both Sides or just One Side? Or Rear as well?
Funny you mention this. We got to a campground and I went back to disconnect the toad. Brake smell from a rear disc brake on E450. The rear calipers had been changed not all that long ago so I suspected the slides were sticking. Went under w/WD-40 and mallet. Knocked calipers till I could see they were loose. FYI, these brakes have the slide keepers pictured here by Cloud Driver
And I hate them. E350's have the typical booted slide bolts.
Anyhow, didn't overheat on the way home but IR heat gun showed right rear warmer than the rest. Took both sides apart at home (and found the tire problem that started me on another thread...). Found dirt, rust, grit, in the slides but no glazing or discoloration of rotor or pad. No heat checking pattern on rotors, just mirror surface. Made sure the pistons moved freely and assembled with this Permatex 24125 slide goop.
That's all I plan on doing. Will monitor of course.
I found the bleeder screws badly stuck, had to replace one, so I cleaned them up and applied a little Never Seez. Will do that on the front calipers as I install the wheels with those new tires. If you're up to it, I'd pull a wheel and inspect the brakes. New pads for these trucks have lining about twice as thick as the steel backing plate. From what Cloud Driver said in his brake thread, new Ford pads aren't that much more expensive than most others. When you squeeze the pistons back to make room for new pads (and maybe just to get the old ones back on) fluid'll go back to the master. Pull excess out with a baster. Then get it as low as you can and fill with fresh DOT3. Bleed LOTS of fluid through. Do all the brakes even if you're only working on one axle. Bleed till the fluid looks good then top off. Shade Tree brake flush.
