bluebarry1964b's avatar
Oct 04, 2013
Brakes overheated-must I replace calipers
The front disc brakes on my RV (class A, if that matters) overheated. I smelled something burning, then my tire sensors on both front wheels set off the alarms on the tire monitoring system. Both tires were 170 degrees. It looks as if the brakes were sticking. Anytime I've seen something similar discussed on this forum, the advise is always to have the calipers replaced. Yet, a retired heavy duty mechanic who took a look at the brakes stated that all that I needed to do was to have the brake pads replaced & the pins lubricated with an anti-seize lube to prevent the brakes from sticking again. Does this make sense? I can save a lot of money by having this guy do the work rather than taking the RV to a shop. But I don't want to be pulled over on the side of the road 10 miles after starting a trip only to find that the brakes have overheated again. Opinions??
