bsport's avatar
bsport
broke down
Jacks will not go down and bedroom silde went out 6" and stopped. now it will not retract no sound of motor. Passager side slide how con I get ti back in so I can move? If I can manualy retract it OK but how . Nothing out side to turn no place in bedroom unless I can get under bed. Stuck in Sikeston MO going to Fl. 2003 Mandalay need help.
Found trouble pump shot remove hy line retract side and pushed slide shut.
Thanks to everyone for help
bob sport
  • Sounds like a fuse. Check all of the fuses and circuit breakers to make sure that the motor is getting power. Did you check your owner's manual on how to manually retract the slides?
