outofplace
Jan 03, 2016Explorer
Surfsidewood wrote:
We have a 96 fleetwood southwind with a big block fuel injected Chevy engine. We are stuck in a Walmart parking lot. The engine started sputtering and stalled out. I was able to get it restarted and get to an auto parts store and put a new fuel filter on. It started right back up, went another ten miles and it died again. The pump in the tank is coming on when the key is turned to acc. I'm getting fuel up to the top of the engine before the injection system. I'm getting spark from the coil, but it still won't start. I was just able to get a fuel pressure gauge and will check it in the morning, but I'm looking to find out what the spec is for fuel pressure on these injected models is. I figure the pump must be wearing out and when it gets hot it quits, but I would like to know what pressure it should have before I go through the trouble of dropping the tank. Any help would be appreciated. It's not going to be a fun trying to get it done in a parking lot.
I believe the Fuel Pressure should be 9-14lbs on a TBI motor.You would need to monitor the pressure while driving to see if its dropping when it stalls.
38,763 PostsLatest Activity: Dec 05, 2025
