valhalla360
Aug 21, 2021Navigator
jdc1 wrote:
Park next to a tree, houase or block wall. Drill 1/4" hole through the filon (not the plywood). Spray some minimal expanding foam in the hole. Cover the affected area with plywood. Place a few 1X2 braces from the plywood to the wall, wedging it so the filon flattens out. Remove the wood the next day. Caulk the hole.
Ummm...expanding foam is likely to lift an even larger section as it expands with no place to go.
As others have said, there is no good solution.
38,780 PostsLatest Activity: Aug 05, 2026
