Hi there- Is the break buddy design to apply the toad vehicle breaks every time you apply your breaks on the MH? or this is only a break away system? Thank you all>>>
Its an adjustable feature. You can adjust it to applying brakes nearly every braking instance on your MH or you can adjust it as I do: It only applies on panic stops. Or anything in between. I really only depend on mine as a stopping device in case of its breaking away from the MH.
