B_B_Upch's avatar
B_B_Upch
burned plug
can someone tell me what could have caused my plug to burn up? I have an rv with a 50 amp to 30 amp adapter plugged into a 30 amp plus outside. I just noticed the one side of the adapter on the 50 amp side was black & a little melted. so I checked the 30 amp plug at the house & it was melted on the same side. any help? I know I will need a new 30 amp extension cord & 30 to 50 amp adapter but want to figure out what caused it so not to happen again. thanks
  • Brian,
    Save some trouble and money. Only replace what was damaged and don't buy a whole new cord.
    The reason things are heat damaged is that they were not capable of carrying the load. Replace just those parts. But if you are not sure which was the bad part, replace both.
    It is very easy to do this if you are running a 50 amp coach on a lesser service. You have to be very careful.
    Matt
  • The most common cause is the connection not being properly installed and tightened.
  • Only a weak or otherwise poor connection wil cause that. Probably just worn. I would replace both.
    You should also be careful how much current your pulling through the 30A adapter. Only two large items (AC & water heater for example) at a time when on 30A.
