Artum_Snowbird
Mar 04, 2018Explorer
mat60 wrote:
My new TT has ST 205/75R14/C. On the sidewall it says max weight 1570 LBS.. 4 tires gives me a total of 6280 LBS.. My trailer total GVW is 6900 LBS. If I travel light I should make the 5 days. :)
It seems to cut costs they give you tires that carry the weight on the wheels when it's hooked up. Having said that, if you have 15% on the tongue and you don't fill it to the brim with your goods to reach the GVW of the rig, your tires are likely under their carrying capacity. Not by a lot, but most likely under.
Best solution is find a weigh station and do a wheel by wheel test to see what you are actually carrying.
38,778 PostsLatest Activity: Jun 10, 2026
