mike_brez
Dec 18, 2014Explorer
If you happen to need new bags in the coil springs I would ditch them and get the correct springs for the weight of your front end from Henderson Super Steer The wander $ucks on the P30. I tried for years to get mine to stop doing that. If you can get someone to help you unlock the steering wheel without engine running and have them turn the wheel a turn to the left and then to right have them keep doing this while you look at every joint from steering box to the wheel tie rods looking for play and up down movement from bellcranks. If all checks out I would go for a front end alignment using Hendersons specs.
