lsm
Apr 20, 2017Explorer
Buying advice
Hello everyone. New to the forum. I am about about three years away from retirement and at this point I am in the "investigative" stage of my motor home purchase. I have already read JohnnyT's po...
Mile High wrote:tropical36 wrote:If you want to limit yourself primarily to Spartan Chassis, and they have had their share of trouble. Nothing wrong with a Freightliner, that were mostly rear radiator.lsm wrote:
I have already read JohnnyT's post of buying an motor home and it was great. I do have a very general question. Never having owned a motor home I pose the following question? (numbers and names are only cited for example purposes)
If I decide my budget is 150k (have not settled on a budget yet) would I be better off buying a new motor home that cost 150k (say a Thor) or would I be better off buying a used Prevost that cost 150k? One will obviously be new and the other might be 20 years old. Thanks for the input.
I'm one to always take quality and engineering over newness and drop back in the years to fit my budget. Doesn't have to be a Prevost conversion to accomplish this either, especially if you want slide rooms that will push hard on a $150K budget.
My advice for seriously seeking out a quality unit is for never firstly going through the front door, like most everyone does. Instead, go to the rear and look for a side radiator. If it has one, then most of the rest will follow with a quality built unit, from the ground up. This most always includes, full body paint, a fiberglas roof..etc...etc...Now, go through the front door and to see if you like it, as well as verifying it's worth.
Simply put, no side radiator, move on and save the time.
