lsm
Apr 20, 2017Explorer
Buying advice
Hello everyone. New to the forum. I am about about three years away from retirement and at this point I am in the "investigative" stage of my motor home purchase. I have already read JohnnyT's po...
tropical36 wrote:We looked seriously at a 2012 Revolution and I opened the back. Do you see a serpentine belt? I see all of the fluid reservoirs in the way, and more rear clip to take apart. I'm 5'8" and I would have to work on a stool to reach in there far enough. I turn a wrench enough to stay on top of things, and I didn't see any real advantage. I can access most of mine underneath, and if necessary pull the bathroom floor with the twist of one latch. There is a lot more to work on besides the belt and most is accessed from the sides or on top.Mile High wrote:tropical36 wrote:
keep in mind, that a shop will charge more and some times mucho more in labor hours for rear radiators, in most cases.
I mean how much does it cost for just cleaning a rear radiator, that is susceptible to overheating in collecting dirt and debris?
Funny, I only hear this with people with side radiators. But to each their own.
Really now and don't know how much of a gear head or mechanic, you are with some experience, but do you think you could replace any component back there, including the belt in the same amount of time with a rear fan, rather than a side unit? If your answer is yes, then I sure wish I had you along when replacing a fluid tube in a campground one evening, right before dark, starting to rain and the bugs were biting.
Thing is, the so called professionals, do know this, are many times, no better at it than average and sometimes worse. They are very good at charging big bucks for their efforts, however.
