Bordercollie
Jul 21, 2017Explorer
The chassis of a motorhome ( engine, transmission, suspension, etc.) generally run well over 100 thousand miles before major repairs are needed, IF maintained properly. Do have a pro truck mechanic check over the entire chassis including the engine cooling system, brakes, lights, etc, and give you a list of fixes needed including parts and labor estimates. Tires should be replaced if over six years old by DOT date codes. RV tires may look new but may be unsafe due to sidewall cracking. The "housebox" should be inspected carefully for any water leak damage which may include mold, dry rot, etc. which is very expensive to have repaired. The fridge, roof air conditioner unit, furnace, water heater, fresh water pump, awning as well as house batteries, converter charger and related electrical system devices must all be checked for proper operation and replaced as needed. Without these checks, a ten year old used motorhome can require months and thousands of dollars in repairs before it safe and pleasurable to use for touring and camping
38,782 PostsLatest Activity: Sep 10, 2026
