Beaver_Thunder's avatar
Feb 18, 2020
C12 starting batteries
Was wondering if anyone on here has a C12 and what do they have for chassis batteries to start that motor. I have two Interstate batteries (model 31-MHD with 950 CCA and 1190 CA), with the batteries fully charged, I’m unable to start the engine cold without using the emergency switch. Best I can tell the starter is direct drive and the batteries are good (I have taken the batteries to the Interstate store and they have checked the batteries and say they are in perfect working order). I’m wondering if I have undersized batteries, curious what other C12 owners have set up for battery capacity.
  • A little back ground on the coach. We have owned it less than a year. It has never started cold without the Boost switch. When we bought the coach, it had recently had the inverter replaced, the prior owner said that after that, the chassis batteries would no longer stay charged. So after I got it home and doing some investigation I found that the combiner (magnum ME-SBC) wasn't wired correctly, so after correcting that issue, the chassis batteries are now being charged and maintained. My next step was to take the batteries down to get tested, I figured they were probably bad due to lack of charging (about a year), well they told me that they were fine. I've looked thru the Magnum chassis manual, CAT manual and owner manual and have not found any reference to the CCA required for this engine. Is there any other place I should look? I'm not confident that the batteries are fine either, could be one bad cell but I'm not convinced they are bad either. The batteries are only 2 years old. Anyways, long story. Thanks for the input.
  • This post begs the question. Has your engine ALWAYS done this or is this a new phenomenon? If it's always done it then you need to check if they are the correct batteries. Your user manual should give you that info. If it's new then you need to check other things. My coach uses the same batteries with no issues. Like you though, I did have my batteries checked this year as they were six years old and my coach seemed to struggle to start. "They" told me the batteries were perfect, that is, until they were not. Checking them a week later "they" said two cells were failing. Two new batteries and I'm in business again. YMMV....Dennis
  • Caterpillar 12 liter diesel.
    And, your Caterpillar owners manual or a call to Caterpillar will tell you the minimum CCAs.
