beeman1ExplorerAug 10, 2016Cab heatHow can I disperse the engine heat when I stop from flowing into the coach area. I put roof exhaust fan on and start air asap. It still takes some time for this heat to go. Curtains don't do the trick...Show More
HealeymanExplorerAug 20, 2016IF you laminate a moving blanket to your curtain, it WILL stop the heat leak.It works well in the cold too.Tim
Related ContentOverhead Cab Leak on 2005 Winnie MinnieDominic air/heatingFoam Insulation Under Cab for heat??Heating element?Crew Cab or Regular Cab
