RealRV's avatar
RealRV
Cable TV
I have a Fleetwood w/Direct satellite & cable as well as Local TV antenna . I have been in parks which offer cable and my inside front TV picks up the picture and my outside as well as back TV will not get cable???? Go to another park and all TV's pick up the cable. Any thought on way this is happening?????
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There are now 4 different major types of cable and a few secondary
    The major
    NTSC: This is the old Analog Television, once all systems were like this
    QAM (With sub settings) This is regular Digital Cable.. NOT ALL TELEVISIONS have a QAM decoder.. In fact the one brand that is still made (Actually once again made in the USA) does not decode QAM..
    NTSC.. Some cable systems. like the one I'm on, Simply pass on the signal they get from Over the Air locals.. Do not change it to QAM as many others do.
    ENCRYPTED: you need a "Set Top Box" for these, no matter your TV.
    I have 3 TV's here too. one, when set to cable, does all 3 of the non-encrypted formats, QAM, ATSC and NTSC.. One only does NTSC and ATSC when on "Antenna" and QAM (or NTSC) on Cable (Will not display the digital channels on the local cable) the other two do all 3 when on cable ATSC, NTSC and Qam.
    Very confusing.. thankfully I figured 'em out.
  • Some parks have digital cable and others have analog.
    When all your TVs receive cable, my guess is that the park has analog.
    When some of your TVs don't receive, the park has digital cable & the TVs that don't receive do not have QAM (ie, digital) tuners.
  • Maybe the front TV scans for both analog and digital and as said above, the rear TV doesn't. Like MaverickBBD said check and or fix that.
  • When you do a channel scan on back TV, what kind of cable does it search for? If it is not set on auto, do that and re scan.
  • Do you have a distribution panel the all the inputs go to? Could be that the selector buttons were disturbed and not allowing the signal to go to the other sets. Otherwise you may have a bad connection somewhere is the cable distribution system.
