clinedinstjt's avatar
clinedinstjt
cable TV
trying to watch cable tv. having problems trying to view. over the air works fine,but having problems trying to hook up to cable. is there a switch I need to change to get cable. 2015 mountain aire 4501 with all the bells and whistles. thanks
  • there is also a place in the tv menu to switch over from air to cable so you tv reads the proper signal
  • Really good picture that presents the best vies of the facts. Pity how many people can't read it.
  • RoyB's avatar
    RoyB
    Explorer II
    I always thought this was a neat pictorial on how the WINEGARD WALL PLATE works...
    When watching from the CABLE TV PORT you will need to make sure the PUSHBUTTON shown above is OFF (No light ON)...
    Roy Ken
  • On most rigs simply connect coax from RV park cable to exterior coax input and connect coax from interior cable output to rear of TV, lastly TV antenna booster must be turned off for cable tv signal to pass through.
  • There may be a switch that turns off the power injector for the OTA antenna that also switches between the antenna and cable inputs to the TV. Hopefully someone with a similar RV model will be along that can help with locating it.
