rbreak wrote:
Thanks for the replies. I was not even close to being overweight, I can't remember the exact numbers (have them at home) but there was plenty of room left before approaching GVWR. It's got plenty of room between the axle and the rubber bump stops so I don't believe bottoming out is happening, if it was the axle (or chassis) would have to be traveling a lot up and down. I tried a max of 60psi in the bags, maybe I need to try 80-90 and see what happens.
I think the pressure in the bags may be exacerbating the problem. But I may be exactly wrong! Try both high and low pressure see which works best.
