ldshafExplorerJul 27, 2014campground elect.normal electric is in the 120-amp. range. at what point in amperage drop do you consider power low enough to do damage air-condishers and other elect. applinces ????
Hiking_HunterExplorerJul 27, 2014Line voltage is nominally 117 volts. You should be OK down to 8% below this. Below 107 volts I get nervous and pull the plug.
