RayChez wrote:
So you air down the tires so that you do not get stuck in the sand, and then how do you air them back up?
You mean to tell me you are going to drive that heavy coach with low air pressure on the paved road until you get to a service center?
It sounds to me like a good way to blow up or ruin a tire.
Some of these idea's are simply amazing to me. These 22.5 tires are not that easy to fill up again. You can not do it with a small compressor like a automobile. You need a big compressor to refill those tires.
There are guys who set up stations right on the beach to air your tires back up as you leave. I think they were charging $3 per tire or something along those lines. They appeared to have fairly large compressors with generators running so I assume they could put out 100 psi. I'm not sure if they charged more for the big RV tires or not.
