gsf35099
Jan 19, 2015Explorer
Sprig wrote:gsf35099 wrote:
...converter go bad ( no DC power between positive & neutral)...
Proper terminology goes a long way in helping to understand the problem. A DC source is typically measured between positive and ground (or negative), not neutral.
At the moment, since you didn't mention anything other then GCFI going out, I'd consider them two separate issues.
Is the breaker for the 110 for the converter tripped?
Not to be a smart a$$, but you are apparently not familiar with my type of DC conver (IOTA 30 amp). There are output lugs labeled "positive, neutral, & ground". Between positive & neutral the output is zero. Between positive & ground the output is 20.7v.
38,763 PostsLatest Activity: Dec 05, 2025
