Cheryl_B
Jun 11, 2016Explorer
Hank85713 wrote:
to the OP, the use of the bumper mount is kinda like what I said I did. DO NOT mount to the bumper as most are not heavy enough to take the weight. You will need to hook up to the frame. I used 2 of the bumper receiver mounts, attached to the frame with gr 8 bolts. I ran the rails out PAST the original hose bumper/carrier and now it only holds some of the weight. Due to the weight I do not carry the spare out there, but did add a reciever carrier and added a plastic work box to carry the stuff that I would normally have to put in bed of truck.
As to the flex pipe, I dont know what was read, but I said to use flex pipe as a way to run the exhaust out if putting the genset in the cubby hole.
Thanks for that info on the bumper and what it can handle. So it's not a good idea to have a spare tire mounted there either?
