klm
Oct 15, 2013Explorer
Can batteries test "ok", but still be bad?
Let me begin by saying I have no knowledge/skills when it comes to all things mechanical, etc. This saga begins when I was parked for 5 mo season, and used a battery tender on the engine start batteries (2). After several attempts, finally got the tender to get to the "float" mode - needed to clean posts to get there, also had batteries tested, put under load and tested - all good according to the mobile tec. Departure day, the tender was no longer in "green float/charged mode", but indicating low voltage - not sure when that happened as I did not check tender every day. Anyway, the engine starts, first try - good - the dash gauge read slightly below "normal". I am thinking the batteries will charge as I am driving. Wrong, they are draining. The alternator was bad, had it replaced - tec put charge on batteries, tested them, said they were ok. I am leary of their reliability. I have arrived at my winter camping spot and have the tender connected - 1 1/2 days, still in charge mode - this is after 2 days of driving - the batteries should be near fully charged - so not sure why the tender is taking so long. The batteries are Delta, 2 1/2 yrs old. So, is it possible that even after being tested by different tecs that one or both of these batteries are bad? What other steps can be taken to test these batteries? Would you replace them? thanks
Kathy
Kathy
