Kidoo's avatar
Kidoo
Can I install two thermostats to control one furnace?
Hi, I am trying to install a second thermostat to control different rooms in the MH. One is already installed in the living area and I would like to install a second one in the bedroom. Anyone done this before?
Reason is I could control the temp of the bedroom when sleeping and vice versa, living room during the day. This way, I could direct the heat in the bedroom only by closing the heat register in the living room and close the room door.
When I use the thermostat in the living room while sleeping, there is a big area to get warm and the thermostat activate the furnace until it gets to the preset temp in the living area, but the room could be warm up much quicker if the thermostat would be there. With a second thermostat, I could probably be able to heat up the RV / room with much less power and propane.
