michelb
Oct 04, 2013Explorer
Ivylog wrote:michelb wrote:
Personally, I really wouldn't worry about it as you are probably only planning on using the smaller spare for emergency anyway and would eventually replace it with the proper size. Driving a few hundred miles with mismatched tires is not really going to have any effect.
X2 if you put it on the front at max pressure.
Good point about the pressure; the smaller tires are likely to have a lower carrying capacity so you'll need to have them more inflated to get the right capacity. Also running at max will mean you get the least amount of tire 'compression' under the load as possible which will help compensate for the fact that they are a bit smaller.
38,778 PostsLatest Activity: Jun 10, 2026
