hotjag1's avatar
hotjag1
Explorer II
Jan 06, 2019
Can I use a WDH on a DP
I tow a 22' enclosed trailer behind the DP in my signature. It has a 10,000 lb hitch with a 1000 lb tongue weight capacity.
I have been hauling a UTV weighing 1100 lbs in the front and a 3200 lb Suzuki Grand Vitara in the rear. I recently weighed the tongue with a scale(Sherline) and it weighed 1400 lbs...yikes!
The only loading option I have is putting the UTV in front and then load the Vitara backwards so that the engine is behind the axles. This reduced the tongue weight to 1200 lbs.
Is 200 lbs over the tongue rating a big No No, or do the manufacturers allow for a little overage? If not, how do I use a WDH on a DP?
It has ride height valves(always sits level)no matter how much weight is on the hitch, so how can I know if I am adjusting weight from rear to front of the DP?
There are people a lot more knowledgeable than me on here so I welcome any options or suggestions.
