guaranteed wrote:
Tomorrow I will take the RV in have it fully filled with vent open till I get propane gas. I will then drive it home and SLOWLY open valve as noted. Does that sound like a good next try? If that does work should I not get propane vapor from tank outlet valve before the reg? I have no problem changing the regulator but at this point it would seem a problem with tank.
It does not matter if the tank is full or not. The tank only fills to 80 percent anyway.
Most likely a regulator or the automatic shutoff safety switch inside the MH>
Pogoil.
