Dutch_12078
Jan 11, 2015Explorer III
Kaven, in re-reading your initial post, I see one point that got by me. You mentioned you have the "1/3, 2/3..." display inside. In that case, you already have a sending unit on your tank gauge, and you only need to trace the wire to the existing panel and connect it to a new 0-90 ohm fuel gauge, 12-volt source, and ground. those can also be found at the existing panel. Just mount the new gauge near it to minimize the new wiring needed. My apologies for not noticing the oversight sooner.
38,766 PostsLatest Activity: Jan 10, 2026
