Problem solved over at IRV2.com. Right behind the diesel tank door is the door for the water tank. There's a valve for some reason that turns off the ability to fill the fresh tank from that connection.
I had someone mention the pliers thing, but it was for plastic valves. Mine is brass.
I could feel the valve working, so I was completely in the dark as to why it would not fill.
This isn't my first RV, just my first one this nice.
Now I have to figure out why I have amazing hot water pressure but very low cold water pressure.
I found the drain was open, and the valve at the top left was closed and that was the problem.
