jmerritt
Jul 27, 2013Explorer
Do you have a meter so that you can meter both 110V circuits from your 50 amp power chord to your service panel? Verify you have 110v at both circuits. If not then you either have a bad 50 amp plug or a bad connection at the park pedestal. Also, check to see if you have a junction box between your power chord and the service panel. If you do check the connections there to be sure everything is clean and tight. Converters convert AC to DC and you problem sounds more like an AC one, a missing side of your 50 amp service sounds more like your problem.
John
John
