YC_1
Jul 27, 2013Nomad
If you still have issues. Make sure the breaker panel in the RV is not blocked by a closed closet door. If it is,open it and get a fan going on the front of the panel to get the breakers cooled off. Inside the panel is the EMS load shedding circuit board and the AC breakers themselves lose capacity with heavy heat loads. I recently had this issue after 5 years of use. Seemed a bit strange. I placed 1/8 inch spacers behind the screws to hold the face plate out a tiny bit. Runs much cooler now.
