MrWizard
Jul 27, 2013Moderator
NO.. a converter is a battery charger, not it will not drag down your 120v power on a 50amp service
IF you have a COMBInation converter/inverter
you maybe have problems on a circuit that uses the inverter part
if a relay or circuit board is bad or if there is loose wiring
how ever your A/C units should not be on the inverter circuit
flutesinger wrote:
Someone told me this could be a weak converter which could be reducing the 120 power the ac needs to run does that sound reasonable.?
