Wilson123 wrote:
I purchased a 2004 Southwind. The hitch shows 10,000 lb tow weight with a 400 lb tongue weight.
Most hitches are rated for 10,000lbs but you are limited by the weakest part of the system(engine, transmission, suspension, etc). You need to find out what your GCWR(Gross Combined Weight Rating) is and what your weight is ready for travel then take the difference. It is probably much less than 10,000lbs.
There are a lot of advantages to the trailer but it will probably at 1,500lbs or more, require periodic maintenance and take a lot of space in campgrounds. You should figure on new tires every 6 years regardless of wear. I like the idea of not having to install brakes and towing lights on the car plus it is easier to back up than a toad.
