I have an Eclipse motorized awning that won't retract. Upon inspection I found the roller tube end cap cracked and slipping on the gear box shaft. Carefree only sells the whole assembly for $230. This...
Look at the shaft the cap goes on to see if it has one flat or two. The shaft with two flats on it has replaced the single flat drive shaft. Either way the cap is not available separate.
