Executive45
Mar 21, 2017Explorer III
Tinstar, there should be a number on the existing strut..you most likely will have to remove it..no biggie. With the number you can search for the replacement. I replace the two that raise my engine compartment several years ago. Good luck...Dennis
Well, duh! Just checked your profile. Assuming you still have the Windsor, call Monaco. They may be able to give you all the info you need. They'll need the coach number, (located on the RVIA sticker) or the last 6 digits of your VIN. Their number is 800-509-3417.
Here is the manual if you don't already have it. Reading through it, I was unable to find the info you need. For Monaco products try giving Northwest RV supply a call at(541)746-9092. They purchased all of Monaco's inventory when they left Eugene. They have stuff no one else has. They may be able to help...D
38,782 PostsLatest Activity: Sep 10, 2026
