Toddoo's avatar
Toddoo
cargo heater rv3000 replacement
I own a 2011 Monaco diplomat 43dft, came with the cargo rv3000 for heating the undercarriage, I have read the multiple threads and online about the discontinued model for cargo heat. I need the opinion from someone that knows more about these small heaters to make sure my solution will not result in the incineration of my rv. I purchased a back seat heater that was the exact fit and size of my cargo rv3000, I cut the electrical connector off the cargo rv3000 and plugged it in turned the thermostat dial up to high and flipped the switch inside and it took off and seems to be working fine. The question I have is why from all the threads I have read, why is no one else using this same set up?? Has anyone else used this set up and let me know if it worked well for them and if I need to be concerned about anything. Thanks todd
