wa8yxm
Aug 02, 2020Explorer III
Answered elsewhere but just recalled something.
The BEEP BEEP Means the remote is working but is it on A/C or some other mode like HEAT? (Forgot that in my other response)
It also means 12 volts is getting to the unit and the electronic part of the controls is working
now on the 120 volt side of life
On my rig I had that problem when nearly new (less than 5 months) found several screws loose in the breaker box.. NOTE UNPLUG BEFORE TIGHTENING one took over 3 turns A/C worked fine after that till they failed due to Bad Design.
Still work fine now that they have been upgradeed.
There are relays on the control board... IN my RV I have two OTHER control boards that have failed.. On one I've diagnosed relay failure (Will rebuild)
Plugs can unplug. wires get moused. For both Blower and Compressor motors to fail at the same time... Not likely
