SDcampowneroperator wrote:
weigh each axle of your rig loaded to travel, then decide if there is enough capacity to carry your scooters and where.
Do the math that if you add 270# + carrier cantilevered behind or ahead, how it will load your axles.
Keep in mind the see saw effect. Weight behind the rear axle takes weight off of the front axle and the farther behind the weight the more it takes off. If you do not have at least 80% of the max rated capacity on your front axle you will have handling issues.
