klparker
Jun 26, 2019Explorer
CAT 3126B
Have 2001 Itasca Horizon diesel pusher, with CAT 330 (3126B). Changed filters, fuel and water/fuel filter and now it will not crank. Any help is appreciated.
wolfe10 wrote:Ivylog wrote:
Fortunately the OP’s engine had a hand pump, many do not. I would only change a Cat on a hill (nose up) with a full tank plus have the new filter full of fuel changing as quickly as possible.
OR, add a Caterpillar hand primer pump if you have the Caterpillar fuel filter base.
OR add/change your primary fuel filter to one with a primer pump.
Caterpillar primer pump is better as excellent quality and quite a lot higher volume than the "rubber button" primers.
Have seen the Caterpillar filter bases with primer pumps on quite a number of Caterpillar products. Would not hesitate to buy the base with pump used.
