- dons2346ExplorerThis is the best oil filter "wrench" http://www.summitracing.com/parts/wmr-w54056?seid=srese1&gclid=COOnpcXl97sCFWZyQgodRyUADw
They come in different sizes so get one for your Cat and then one for your generator. - Passin_ThruExplorerI had to use a pipe wrench on a 3406 CAT once. I was mad enough to spit out the dummy!
Dummy A small nipple shaped device used to shut up a squalling kid. If he's mad enough to spit one out.......... - stuplichExplorer
lj2654 wrote:
I have a new to us MH and can't get the oil filter loose to remove it. I even tried a strap with a big breaker bar and broke the strap in half...HELP!
lj2654
Try one of these: http://www.harborfreight.com/20-in-professional-groove-joint-pliers-60537.html.....($22.49 w/ "25% off" coupon).
The last time I changed oil I found that SpeedCo had overtightened the oil filter .... to the point that even the "big screwdriver" trick failed!
Mel
'96 Safari, 3126 Cat - keepingthelightExplorer
If you are in the process of draining the oil, you may want to remove the drain plug and punch a hole in the bottom of the filter and let the oil drain out. This may relieve pressure and allow you to undue the filter easier (with a new tool of course).
Good luck;) - tinkererExplorerI use a large channel lock:W
- I_rvExplorerparts store has a metal filter wrench made for large truck filters,i know what your going through been there done that.
- ole_truckerExplorerYou could go to Napa and buy a regular filter wrench, or I have used large pair of channel lock pliers from time to time. On my Endeavor w/that engine there was enough room for them. Good Luck!
- badboy368Explorermight be too late now, but i have found that if the engine is warm and up to temp. they come off a little easier...:h
- smlrangerExplorerMy last ditch effort to remove stubborn oil filters is to punch a hole through them with a big screwdriver and twist them off.
