n4hwlExplorerAug 17, 2013cat c7 oil leakMy cat c7 has about 60k on the engine. I was working on it this weekend and noticed an engine oil leek around the area of the oil filter. It may not be the oil filter leaking but it is definitely on ...Show More
Mandalay_ParrExplorerAug 17, 2013I would clean up the area good so you could see where the leak is coming from before anything else.
Related Contentoil leakNautilus P1 has leaking connectionsCAT HEUI Oil leaks- UPDATEEngine Oil leak Cat C9oil leak
